Aggressive Optimizations
Revision as of 09:01, 19 March 2026 by Alexander (talk | contribs)
Cut off features slowing you down!
  • Use smaller shadow maps (see here why).
  • Use just one light that casts shadows.
  • Use Basic or Bilinear shadow filtering instead of PCF / ESM shadows (check out this info).
  • Do not cast shadows from the point or area lights. They require 6 times more draw calls.
Disable post-processing
Disable HDR rendering
Get rid of light probes
  • Keep IBL map but remove all light sources.
OR:
Set IBL cubemap size to 256
No hardcore anti-aliasing
The instructions are here.
Emission shading only
