Measurement Units
Revision as of 15:13, 24 May 2026 by Alexander (talk | contribs)
Verge3D uses generic units for distance values. These can be anything you want: meters, inches, centimeters, parsecs, etc. However, when dealing with the particular modeling software, some 3D-tool specifics should be considered.
Verge3D for Blender
Verge3D for 3ds Max
Verge3D for Maya
Working Units default to centimeters, however you can assign your own with the Maya's property SettingsWorking UnitsLinear.
The rule of thumb is simple — units that you see in the Maya UI will be exported to glTF and used in Verge3D as-is (no conversion happens).
Angular units
