Measurement Units
Verge3D for Blender
Verge3D for 3ds Max
Verge3D for Maya
Working Units default to centimeters, however you can assign your own with the Maya's property SettingsWorking UnitsLinear. The rule of thumb is simple — units that you see in the Maya UI will be exported to glTF and used in Verge3D as-is (no conversion happens).
