Measurement Units
Verge3D for Blender
1 Blender unit (BU) is 1 meter by default. Switching to some other unit system (e.g. Imperial) does not affect how Blender stores the distances/positions internally (it's purely a UI feature). So, when you export your scene to glTF and load it to Verge3D you will always get meters. Thus, for consistency (with Puzzles or JavaScript) we recommend using the metric system in Blender and always set the Unit Scale parameter to 1.
Verge3D for 3ds Max
Verge3D for Maya
Working Units default to centimeters, however you can assign your own with the Maya's property SettingsWorking UnitsLinear. The rule of thumb is simple — units that you see in the Maya UI will be exported to glTF and used in Verge3D as-is (no conversion happens).
