Home › Forums › Bug Reports and Feature Requests › Reporting an issue with Verge3D
- This topic has 69 replies, 20 voices, and was last updated 3 months, 2 weeks ago by
Alexander Kovelenov.
2021-02-08 at 5:36 pm #38212
winacecilia03
Participant900mb. i tried with my friend wifi, and still same.
2021-02-08 at 5:37 pm #38213winacecilia03
Participant900mb. i tried with my friend wifi, and still error.
2021-02-09 at 6:52 am #38240Yuri Kovelenov
Staff2021-08-05 at 6:16 am #43459haidrmhmmd
ParticipantHello
So i use verge 3D to make a Booth exhibition, in that model i put some video using texture with Mp4 formatIn the first picture :
When i click the normal verge which is (Localhost) link, it normal and i can play the video actuallyIn the second picture :
But after i publish the model, and klik cdn.soft8soft link, the video turn to black and i can’t play anything2021-09-12 at 9:03 am #44543yurikruglov
ParticipantI got an issue. Exploding model to parts and making render order fixes it
2022-05-12 at 9:10 am #51976adamgraszk
Participantis it possible to add withnosietextur then it was possible to make glass material as in this tutorial
2022-05-13 at 6:40 am #52023Mikhail Luzyanin
StaffPut it in TODO list.
2022-09-07 at 9:18 am #55642Bernhard Glettler
CustomerHello, i could manage it to get the app running on desktop, but so far, no luck on mobile …
What possibilities do i have to have faster load times or even just loading the app in first place beside long loading time?2025-03-23 at 6:46 am #80844wangrui
ParticipantAfter updating version 4.9, the icon can’t be loaded, but the function can be used. When you enter the web development mode, you find that the svg file response is 00000000.
2025-03-23 at 9:01 am #80848Alexander Kovelenov
StaffAfter updating version 4.9, the icon can’t be loaded, but the function can be used. When you enter the web development mode, you find that the svg file response is 00000000.
What OS version you use? Have you upgraded from another version? If so you might cleanup the old version entirely and install 4.9 from scratch.
Also, please copy-past the content of the app manager log: http://localhost:8668/log
2025-03-23 at 9:53 am #80850wangrui
ParticipantV3D-AM-INFO: Starting App Manager server (Verge3D for Blender)
V3D-AM-INFO: Serving network port: 8668
V3D-AM-INFO: System: Windows-10-10.0.19045-SP0
V3D-AM-INFO: Python: 3.12.1 (tags/v3.12.1:2305ca5, Dec 7 2023, 22:03:25) [MSC v.1937 64 bit (AMD64)]
V3D-AM-INFO: Executable: D:\Verge3D_for_Blender\python\windows\python.exe
V3D-AM-INFO: Filesystem encoding: utf-8
V3D-AM-INFO: Version: 4.9.0 (RELEASE)
V3D-AM-INFO: License: Trial (expires 22.04.2025)
V3D-AM-INFO: Root folder: D:\Verge3D_for_Blender
V3D-AM-INFO: Applications folder: D:\桌面\桌面\verge 3D
V3D-AM-INFO: Network cache age: 15 minutes
V3D-AM-INFO: Temporary folder: C:\Users\Administrator\AppData\Local\Temp\verge3d_tmp_lkzbcxg3I have cleaned up the old version, downloaded the new version 4.9 again, and tried to restore the old version to no avail.
2025-03-23 at 10:55 am #80851Alexander Kovelenov
Staff2025-03-24 at 10:18 am #80853wangrui
ParticipantIt won’t.I understand that there is another community group in China that is in the same situation as me, which may be a problem that needs attention.
2025-03-24 at 11:47 am #80855Alexander Kovelenov
StaffIt won’t.I understand that there is another community group in China that is in the same situation as me, which may be a problem that needs attention.
Try one of these steps:
1) Check if some other browser works (e.g. Firefox)
2) Reset App manager settings with http://localhost:8668/reset
3) Restart your PC then install Verge3D into some other folder
4) Check Blender addon settings, maybe Verge3D addon is loaded twice or have different versionAlso please provide the contents of Blender console (Window ‣ Toggle System Console menu).
BTW what Blender version you use?
2025-03-25 at 3:48 am #80868dx556po
ParticipantI also have the same problem, not just http://localhost:8668/ The icon is missing, just like the SVG file provided in the case. It was missing when I turned on my computer today. Is this because I used Google Web Designer?
