Styling Verge3D Applications
Learn how to customize user interface styles in your Verge3D applications.
Introduction
Along with 3D part, all Verge3D applications include HTML elements for rendering preloader, annotations, fullscreen button and more. All these elements are supplemented by CSS classes which can be easily changed in your own application.
See the src/style.css file for the reference and examples of what can be customized. Do not change this file though as it compiled right into Verge3D. Instead add all styling code right into your application main CSS file. For example if your app is called "My Awesome App" then you should modify the following file:
applications/my_awesome_app/my_awesome_app.css
Alternatively, you can modify your CSS classes by using the Puzzles editor. Check out the set css rule puzzle reference.
Customizing Preloader
To modify your preloader change the following CSS classes:
v3d-simple-preloader-background - for changing background of the entire preloader screen.
v3d-simple-preloader-container - for changing container element with preloader image and bar. By overriding this class you can customize preloader position and size.
v3d-simple-preloader-bar - for changing loading bar.
v3d-simple-preloader-logo - for changing preloader image.
For example, if you need to make progress bar red instead of the default blue, add the following code to your application's main CSS file:
.v3d-simple-preloader-bar {
background: red;
To change the preloader's image to something else:
.v3d-simple-preloader-logo {
background-image: url("PATH_TO_YOUR_IMAGE");
background-size: cover;
Replace PATH_TO_YOUR_IMAGE with the actual URL of your image, such as my_company_logo.png.
Recommended preloader image size is 110x110px.
To assign custom background image instead of default white:
.v3d-simple-preloader-background {
With Puzzles, all three style customizations will look as follows:
Styling Annotations
To style your annotations use the following CSS classes:
- v3d-annotation - for changing the style of the annotation icon.
- v3d-annotation-transparent - for changing the style of semi-transparent (occluded) annotations.
- v3d-annotation-dialog - for styling annotation popup dialog.
For example, to make your annotations square with green background:
.v3d-annotation {
border-radius: 0px;
background: rgba(0, 255, 0, 0.8);
Changing Fullscreen Button
Fullsceen button styling is already managed by your application. See the following classes in your app's main CSS file:
- fullscreen-button - for changing the style of the both open and close fullscreen buttons.
- fullscreen-open - for styling the image for entering (opening) the fullscreen mode.
- fullscreen-close - for styling the image for leaving (closing) the fullscreen mode.
For example, if you need to change the default open/close images to something else, modify the following two classes:
.fullscreen-open {
background-image: url('PATH_TO_OPEN_IMAGE');
.fullscreen-close {
background-image: url('PATH_TO_CLOSE_IMAGE');
Got Questions?
