Animation System
Overview
Within the Verge3D animation system you can animate various properties of your models: the bones of a skinned and rigged model, morph targets, different material properties (colors, opacity, booleans), visibility and transforms. The animated properties can be faded in, faded out, crossfaded and warped. The weight and time scales of different simultaneous animations on the same object as well as on different objects can be changed independently. Various animations on the same and on different objects can be synchronized.
To achieve all this in one homogeneous system, the Verge3D animation system has completely changed in 2015 (be aware of outdated information!), and it has now an architecture similar to Unity/Unreal Engine 4. This page gives a short overview of the main components of the system and how they work together.
Animation Clips
If you have successfully imported an animated 3D object (it doesn't matter if it has bones or morph targets or both) - for example exporting it from Blender with the Blender exporter and loading it into a Verge3D scene using GLTFLoader, one of the geometry's properties of the loaded mesh should be an array named "animations", containing the AnimationClips for this model (see a list of possible loaders below).
Each AnimationClip usually holds the data for a certain activity of the object. If the mesh is a character, for example, there may be one AnimationClip for a walkcycle, a second for a jump, a third for sidestepping and so on.
Keyframe Tracks
Inside of such an AnimationClip the data for each animated property are stored in a separate KeyframeTrack. Assumed a character object has a skeleton, one keyframe track could store the data for the position changes of the lower arm bone over time, a different track the data for the rotation changes of the same bone, a third the track position, rotation or scaling of another bone, and so on. It should be clear, that an AnimationClip can be composed of lots of such tracks.
Assumed the model has morph targets (for example one morph target showing a friendly face and another showing an angry face), each track holds the information as to how the influence of a certain morph target changes during the performance of the clip.
Animation Mixer
The stored data form only the basis for the animations - actual playback is controlled by the AnimationMixer. You can imagine this not only as a player for animations, but as a simulation of a hardware like a real mixer console, which can control several animations simultaneously, blending and merging them.
Animation Actions
The AnimationMixer itself has only very few (general) properties and methods, because it can be controlled by the AnimationActions. By configuring an AnimationAction you can determine when a certain AnimationClip shall be played, paused or stopped on one of the mixers, if and how often the clip has to be repeated, whether it shall be performed with a fade or a time scaling, and some additional things, such crossfading or synchronizing.
Animation Object Groups
If you want a group of objects to receive a shared animation state, you can use an AnimationObjectGroup.
Supported Formats and Loaders
Note that not all model formats include animation (OBJ notably does not), and that only some Verge3D loaders support AnimationClip sequences. Several that do support this animation type:
Note that 3ds max and Maya currently can't export multiple animations (meaning animations which are not on the same timeline) directly to a single file.
Example
var mesh; // Create an AnimationMixer, and get the list of AnimationClip instances var mixer = new v3d.AnimationMixer(mesh); var clips = mesh.animations; // Update the mixer on each frame function update () { mixer.update(deltaSeconds); } // Play a specific animation var clip = v3d.AnimationClip.findByName(clips, 'dance'); var action = mixer.clipAction(clip); action.play(); // Play all animations clips.forEach(function(clip) { mixer.clipAction(clip).play(); });
